Counting stars using estimation
Decide on a systematic way to estimate the number of objects in an image
In this engaging STEM activity, designed for secondary school students, learners will take images from the Hubble telescope and use them to estimate the number of stars contained in those images.
Activity: Counting stars using estimation
The first slide in the presentation below introduces students to the context of the challenge and pushes them to think about how mathematics can be used to solve a real-life problem.
The second slide asks the students to estimate the number of stars in the image. A Geogebra file “counting stars” which subdivides the enlarged image into smaller grids for sampling has been supplied.
Students will need to find a systematic way of estimating the number of objects in the enlarged image.
One approach is to subdivide the enlarged image into smaller sections, count some of these and work out the mean. This mean can then be taken as the number of objects per subsection and multiplied by the number of subsections to get an estimate of the number of objects in the enlarged image.
To obtain an estimate for the number of stars in the original image, this figure then needs to be multiplied by the number of enlarged images in the original image.
Students will need to consider when to round off and what degree of accuracy is appropriate.
Discussion points
Comparing the different estimates obtained by the students would be interesting. Looking at the differences in their estimates for the number of objects in the enlarged image first and then observing how this transferred to the differences in the original image.
Extending the problem
This method is used in a wide variety of contexts, from estimating the number of hairs on someone’s head to auditing the number of insects in an enclosure at a zoo.
This activity could be extended by looking at capture/recapture as a method of estimating animal populations.
What is the Hubble Space Telescope?
The Hubble Space Telescope is a space telescope that was launched into low Earth orbit in 1990 and remains in operation. Although not the first space telescope, Hubble is one of the largest and most versatile, and is a well-known research tool for astronomy.
With a 2.4-meter (7.9 ft) mirror, Hubble’s four main instruments observe in the near ultraviolet, visible, and near infrared spectra. Hubble’s orbit outside the distortion of Earth’s atmosphere allows it to take extremely high-resolution images, with substantially lower background light than ground-based telescopes. Hubble has recorded some of the most detailed visible light images ever, allowing a deep view into space and time. Many Hubble observations have led to breakthroughs in astrophysics, such as accurately determining the rate of expansion of the universe.
Potential GCSE content covered
In this activity students will cover mean average, rounding and accuracy and reasoning from calculations.
Download the free activity sheets below!
