Model boat maths challenge for GCSE
Calculate the distance a model boat will travel across water
Two friends are on opposite banks of a river which is 30m wide. One of them has a model boat and plans to send it across the river to the other. The boat has a small motor which moves it forward. Once the boat is in the water, it cannot be steered. Can you calculate the distance that the model boat will need to travel across the water?
This fun maths challenge will teach students about forces and motion and is perfect for GCSE students!
Activity: Model boat maths challenge for GCSE
The students can work individually or in pairs. Download the teacher presentation below and allow the students some time to read the task on the first slide, then show them slide 2.
Students will need to find the distance downstream from the starting point. A generalised approach to such problems should be introduced along with slide 2.
Leave the students to work on the task and then compare approaches and answers. A GeoGebra file has been supplied to help with the discussion.
Problem Solving
The students can tackle the problem in a number of ways. Some may choose to look at the path of the boat at 1 second intervals, possibly plotting the path on a graph. This is the way the GeoGebra file works. Others may use trigonometry to find the angle the boat travels and then use this with the 30m width of the river to find the distance downstream.
Another approach would be to use a scale drawing.
Pythagoras theorem or trigonometry can be used to find the displacement of the boat from its original position.
The GeoGebra file may be useful to students who wish to gather some results for the general approach or to check their answers.
Discussion Points
This activity could provide an opportunity to introduce vectors and possible resultant force, making a connection with Physics.
Comparing the advantages and disadvantages of various approaches would provide students with the opportunity to consolidate their learning.
Extending the problem
It could also be possible, with some students, to consider how to point the boat upstream, so that it ends up at the point directly opposite the start.
Potential GCSE content covered
In this activity students will cover graphs, Pythagoras theorem and vectors.
