Age Range: 11-14
Duration: 60 or more mins | 30-59 mins
  • Physics
  • Mathematics
Daylight hours maths activity
Looking at the length of the day through the seasons and predicting the longest and shortest days
The length of the day varies with what time of year it is. Can you put your maths skills to the test and work out the longest and shortest days of the year?
This activity is one of a series of resources designed to allow learners to use the festive season theme to develop their knowledge and skills in Mathematics and Engineering.
Activity
In this fun STEM challenge, learners will use a data sheet to plot a graph and then interpret the data to determine the fate of the longest and shortest days of the year in the United Kingdom.
This activity could be a main lesson to teach about the different times of the day and the use of the 24-hour clock. It could also be used as a part of a wider scheme of learning focusing on keeping time or how the solar system works.
Some learners may already know when the shortest and longest days are. If this is the case, they can try to see if their calculations back up their knowledge. The rest can have a go at guessing before the answer is revealed.
The history of time measurement
The history of measuring time dates back thousands of years; ancient civilisations like the Egyptians, Mesopotamians, and Greeks developed sundials and water clocks to track the passage of time. The invention of mechanical clocks in the Middle Ages brought greater precision. The pendulum clock, followed by the quartz clock, revolutionised timekeeping. Today, atomic clocks are the most accurate timekeeping devices. Time measurement has evolved from celestial observations to sophisticated technological advancements, shaping our understanding and organisation of daily life.
Engineers must be able to interpret data to understand how things work. For example, drawing a graph of how much material in a product is lost over time due to corrosion so that they can determine when to replace the product.
By the end of this activity, students will be able to understand how to plot a graph from data, they will be able to interpret data, and they will be able to determine the longest and shortest days of the calendar year.
Oh ho ho, please share your classroom learning highlights with us @IETeducation! #SantaLovesSTEM
