Halloween treasure hunt
Using coordinates, angles and directions to locate pirate treasure on a map
Locate buried treasure on a pirate map and develop your maths knowledge in this fun activity for kids!
In this exercise learners will look at different methods to find position and direction on a map. They will learn how to use coordinates and bearings using angle and distance. They will work with a pirate treasure map and a series of worksheets to work out where the treasure is. Differentiated worksheets are available, allowing the learners to progress from using simple coordinates and vector coordinates to polar coordinates using bearings with angles and distances.
Activity: Halloween treasure hunt
This is one of a set of free STEM resources developed to support the teaching of the primary national curriculum. They are designed to support the delivery of key topics within maths and science. This resource focuses on position and direction using vector and polar coordinates, with the theme of a pirate treasure map.
This activity could be used as a main lesson activity for KS2, to teach learners how to use coordinates and angles. Further number skills may be used to work out map scale and distances.
This exercise could be carried out as individuals or in pairs. The learners will find buried treasure on a pirate map, using various methods to find position and give direction.
Students will follow the instructions on the ‘Treasure Hunt’ worksheet and add the positions and lines of direction on the Treasure Map using a ruler and pencil.
The worksheets are progressive; The first worksheet uses coordinates, the second uses vector coordinates and the third worksheet uses polar coordinates.
This activity will take approximately 40-60 minutes to complete.
Tools/resources required
- Activity and worksheets
- Protractors (360 degree)
- Rulers
- Pencils/Coloured pencils/Pens
- Erasers
When planning to build new stadiums and large industrial sites, civil engineers need a good understanding of map reading skills to make sure that the buildings are built in exactly the right place. Engineers use special equipment to get the bearings and distance correct.
By the end of this activity students will be able to describe a position on a map or grid, they will be able to give directions to a specific point on a map or grid using vector coordinates and they will be able to give directions to a specific point on a map or grid using polar coordinates.
Download the free Halloween treasure hunt activity sheet below!
Available Downloads
Activity overview
Activity description, teachers' notes and curriculum links.
Presentation
Powerpoint guiding you through the activity.
Family activity
Instructions on how to do the activity at home
Halloween treasure map
Blank treasure map to hand out to students.
Worksheet
Halloween treasure hunt - Worksheet 1
Worksheet
Halloween treasure hunt - Worksheet 2
Worksheet
Halloween treasure hunt - Worksheet 3
Halloween treasure hunt - Worksheet 1 answers
Halloween treasure hunt - Worksheet 2 answers
Halloween treasure hunt - Worksheet 3 answers
