Design a personal heart monitoring system with the micro:bit
Programming the micro:bit using an accelerometer and LED display
In this activity, learners will develop their programmable system using the BBC micro:bit’s inbuilt accelerometer to detect motion created by the pumping of the heart.
There are many reasons to monitor heart rate. For example:
- There are 2.7 million people in the UK currently suffering from heart problems. The quicker these problems can be found and treated the better the chance of a full recovery.
- Athletes measure their heart rate during training to ensure that they are training in their optimum physical range.
This BBC micro:bit accelerometer project is an ideal activity for teaching students how to integrate a programmable system into a product design. It’s one of a set of resources developed to aid the teaching of the secondary national curriculum, particularly KS3, supporting the teaching in computing and design & technology (D&T). The activity can be used as a main lesson, with Social Effects of Health Management as the starter.
Activity: Programming the micro:bit using an accelerometer and LED display
Students will use the BBC micro:bit to develop a prototype for a personal heart monitoring system.
To create a micro:bit personal heart monitoring system, students must:
1. Understand the brief
Using the Programming The System Health Check presentation students will review the design brief, including the importance of heart monitoring for health and fitness.
2. Review the system diagram
Students will review the presentation, which shows a block diagram of a heart monitoring system. Students can use this systems diagram as an example of how they can plan out their own health monitoring system.
3. Follow the design criteria
Students will review design criteria, which explains that the system must:
- Integrate the BBC micro:bit
- Use the micro:bit’s inbuilt accelerometer.
- Have an LED display to show the heart rate.
- Use either a buzzer or a beeper as a sound output.
4. Use an accelerometer
The accelerometer must be used as the input device for the micro:bit to detect subtle movements caused by a beating heart.
5. Choose output device
Students can connect either a buzzer or a beeper to their micro:bit, which will give an audible indication of a person’s heart rate. They will also use an LED display to show heart rate information.
6. Code the Program
Students will then write their programme, using the either the JavaScript Blocks Editor or Python Editor. The programming should focus on the key tasks of reading data from the accelerometer, processing that data to calculate an approximate heart rate, displaying the heart rate on the LED screen, and optionally activating the buzzer/beeper in sync with the person’s heart rate.
Example programs can be used as guides where necessary (see below).
7. Download and test their programme
Students will download their programme onto the micro:bit and make adjustments and improvements (if necessary).
Where can I find the example programme for making a personal heart monitoring system with the micro:bit?
The instructions for where you can find and download the example programmes for the JavaScript Blocks Editor and Python Editor are below:
Example accelerometer program – JavaScript Blocks Editor
- Go to www.microbit.org/code and open the JavaScript Blocks Editor.
- Drag the file microbit-heartrate-jsb.hex onto the work area.
- Button A can also be used to test if it is working.
- Test it, download it and experiment with how it works!
Example accelerometer program – Python Editor
- Go to www.microbit.org/code and open the Python Editor.
- Drag the file heartrate.py onto the work area.
What does an accelerometer do on a BBC micro:bit?
An accelerometer is a motion sensor that measures changes in movement along different axes. It can detect if something is speeding up, slowing down, or even changing direction.
On the BBC micro:bit, the accelerometer's sensitivity allows it to pick up the tiny vibrations caused by a heartbeat. By programming the micro:bit to analyse those vibrations, you can create a simple prototype heart rate monitor as when the accelerometer detects movement the LED screen will create a graphical representation of the heartbeat. A buzzer or beeper can also be added for the beats.
Engineers use accelerometers in a wide variety of devices, including smartphones (for screen rotation and step tracking), drones (for stabilisation), and fitness/medical devices (for monitoring movement and heart activity). By learning to program an accelerometer with the BBC micro:bit, students will develop coding skills relevant to fields like robotics, biomedical engineering, and product design.
Students will understand how to read a block systems diagram (specifically for a heart monitoring device). They’ll also be able to understand how accelerometer can be used as a heart monitoring device. Finally, they’ll be able to programme the BBC micro:bit so that their system meets the design criteria.
Available Downloads
Activity overview
Design a personal heart monitoring system activity description, teachers' notes and curriculum links.
Presentation
Using an accelerometer and programming the system.
Handout
Programming the system - student handout showing an example program using the JavaScript Blocks and Python editors.
Hex program
Example programming file using the JavaScript Blocks editor
Py program
Example programming file using the Python editor
Connected health - Podcast
Produced by Fun Kids Radio as part of the Techno Mum series.
Videos
Heart rate monitor
Exploring how the accelerometer function within the BBC micro:bit can be used to measure your heart rate.
