Create a World War 2 air raid shelter
Make a cardboard model of an Anderson air raid shelter.
In this project learners will learn about the protection given to people in the Second World War. They will then make their own model of an Anderson shelter from card.
This activity could be used as a main lesson activity to teach learners about The Second World War. It could also be used as part of a wider scheme of learning focussing on structures or as a focussed practical task focussed on model making.
Activity: Create a cardboard model of a World War 2 air raid shelter
This is one of a series of resources that are designed to allow learners to use the theme of the second world war to develop their knowledge and understanding in Design & Technology and Engineering. This resource was inspired by the themes of the World War 2 and Flight. It supports the teaching of design and technology in context by making a model of an Anderson (air raid) shelter using graphic materials.
Tools/supplies needed:
Resources required:
- Scissors
- Card or cardboard (cereal box)
- Glue sticks
- Masking tape (optional)
- Coloured pens/pencils
Follow our step-by-step guide to make a World War 2 air raid shelter
Construct the shelter building
Step 1 – Cut out the parts
- Carefully cut along all the solid outlines
- Glue onto card or cardboard
- When glue is dry, cut out the cardboard
Step 2 – Scoring
- Score along the dotted line, and fold
Step 3 – Gluing
- Place some glue on the longest tab and hold against the opposite face
- Put glue on the tabs for the side nearest the door and stick against the front panel
Step 4 – Assembly
- Repeat with the remaining side and press until the glue dries
- You could use masking tape to hold it until dry, then remove the tape
Step 5 – Back and front pieces
- Glue the two back pieces together back-to-back
- Glue the two front pieces together back-to-back so that the entrance lines up
Step 6 – Front assembly
- Place glue on the front end of the shelter
- Carefully glue the front piece to the shelter, making sure the entrances lines up
Step 7 – Back assembly
- Put glue on the back of the shelter
- Fix the back panel to the shelter - make sure the panel is central, with the bottom edge lined up with the bottom edge of the shelter
Step 8 – Decorate
- Leave the shelter part of the model to dry
- Decorate the front and back of your shelter to make it look real
Construct the base
Step 1 – Cutting out
- Cut out the base and hole for the shelter
Step 2 – Scoring
- Score the fold in the card and fold
Step 3 – Glue
- Glue the four corner tabs together to form a box shape
Step 4 – Assemble
- Allow the glue to dry, then apply glue to the remaining tabs and stick them down
- Leave the base section to dry
Construct the earth cover
Step 1
- Colour in the grass on the top with a felt tip pen
- Cut out the shape including any tabs
- Score along the dotted lines and fold
Step 2 – Assembly
- Place glue on tabs and stick to the opposite faces
- Let the glue dry
Finished model
- Fit your shelter into the slot in the base
- Place the grass-covered earth section of the model over your model - this provided more protection
Extension
- Design a suitable layout for the interior – what would be needed? How would you arrange everything?
- Remember a whole family would be inside!
The Engineering Context
Understanding about how to keep people safe inspires engineers to develop new materials, objects and structures. This develops the world we live in and improves the quality of living for all.
This resource combines Design and Technology and Engineering with History , with the aim that the learners will be able to know what is meant by an Anderson Shelter and be able to follow instructions and model an idea accurately.
You can download our step-by-step instructions below as a classroom lesson plan and PowerPoint presentation.
