Network Rail maths challenge
A maths-based challenge to find stations on the rail network based on their journey times
Can you use a rail network map to find stations based on journey times? Use your math skills to complete our station hunt activity sheet in this fun STEM challenge for kids!
This is one of a series of free resources developed in conjunction with Network Rail to develop understanding and skills in key maths, science, and engineering concepts.
Activity: Network Rail maths challenge
In this fun maths challenge, learners will use a known starting position (station) and a journey time to identify a destination. It will involve adding different combinations of journey times to identify the answer.
This activity could be carried out as individuals or in pairs and could be used as a one-off main lesson activity to develop basic maths skills in context.
Learners will complete the questions on the activity sheet using the station hunt map as a guide. They should find the starting point station and move along the rail lines, adding up the time as they go along, until they reach their destination station.
The transport speeds are estimates based on typical values, found using the most common search engine. Any statistics or data on transport speeds used in this activity are solely for the purpose of this activity and may not be an accurate reflection of actual current times, which may vary due to seasonal, environmental or legal limitations, for example.
Additional complexity could be added by adding a set time (for example, 15 minutes) when train changes are needed.
As an extension activity, students could work out their own journey time questions and try them on their friends.
This activity will take approximately 30-50 minutes to complete.
Tools/resources required
- Pencils
- Calculators
Calculating times is a vital skill that engineers use – it helps them make decisions about the best way to complete a task. For example, it helps aerospace engineers plan how much fuel to carry on a plane to allow it to fly for a long time.
By the end of this activity students will be able to solve a contextual problem using a time calculation and they will understand how to calculate different journey times between rail stations.
Download the free Network Rail maths challenge activity sheet below!
