Which medical imaging technique - practical
Investigate aspects of biomedical signal processing
The use of different types of signals is hugely important in all areas of healthcare. Signal processing engineers are involved in everything from extracting information from the body’s own electrical and chemical signals to using wireless signals to allow search-and-rescue robot swarms to communicate with each other.
Activity info, teachers’ notes and curriculum links
In this practical session students investigate aspects of signal processing. Working in teams, students convert an analogue brain signal into a digital format and transmit it across the classroom to another team using flashes from the LED on the Digital Communicator that they will need to build. The other team will record the digital format and rebuild the original waveform from that information.
This activity can be used as a hands-on extension to the ‘Which Imaging Technique?’ activity (see Related activities section below).
You can stream and download the related films for free by clicking on the appropriate link in the Related resources section below.
Available Downloads
Activity overview
Which medical imaging technique - practical activity description, teacher's notes and curriculum links
Analogue to Digital Conversion help sheet for students
Analogue to digital conversion help sheet for students.
Building the digital communicator handout
Building the communicator - guidance for students on how to build a communications device.
Sensing illness challenge
Sensing illness challenge extension activity for students.
Waveform Printout worksheet allowing you to create your wave form
Waveform printout worksheet allowing you to create your waveform.
Challenge
Sensing Illness Challenge extension activity for students
Videos
Mind control
Mind mapping
