Design and Technology worksheets
The questions included within these worksheets have all been written by a former senior examiner and will allow students to test themselves without the pressure of an exam setting.
Browse the set or why not download them all, sharing your learning with us @IETeducation on social media.
Please note that these resources and experiments have been specifically designed to be carried out with adult supervision or direction as appropriate, and it is recommended that the instructions are followed safely. All resources and experiments are carried out at your own risk.
Areas
Can you calculate the areas of these different shapes?
Cost
Can you calculate the various costs that could go into the making of a single product?
Density
The density of a material can be used with the volume of a part to calculate the mass of the part. Can you calculate the mass of these objects?
Fractions and percentages
You might be asked to use fractions or percentages when, for example, analysing responses to user questionnaires or calculating the percentage of a material that is used or wasted. Can you calculate the fractions and percentages in this worksheet?
Frequency tables
When a set of data is collected, it is often in a random order. Frequency tables are often constructed to help sort the data. Can you sort the data and fill in the missing fields?
Interpreting graphs
Explore the graphs displayed within this worksheet and see if you can determine the relationship between x and y.
Metric units and standard form
Very large numbers may be written in standard form enabling them to be written down easily. Can you convert the various units of measure into standard form?
Ohms law and resistance
Ohm’s law states the relationship between the current, voltage and resistance in an electrical circuit. See if you can calculate the answers to the related questions in this worksheet.
Plotting graphs
Engineers use graphs to present data in a visual form. here, you may be asked to read data from graphs, explain the meaning of data shown in graph form or to plot graphs from provided data.
Pressure
Pressure calculations are used to work out the output force of a hydraulic or pneumatic system, or the force applied on a material by a press. Have a look at our example and test yourself with some calculations.
Pythagoras
Pythagoras theorem can be used to find out the length of the missing side of a right-angled triangle when the lengths of the two other sides are known. See if you can work out the missing lengths on this worksheet.
Ratios
Ratios show the relationship between two values. See if you can work out the relationships between the numbers shown here.
Stress, strain and Young's Modulus
Testing the strength of a material normally involves applying a force to a test piece and measuring how its length changes. To allow different sizes of test pieces to be compared, this load and extension must be converted into values for stress and strain.
Tessellation
Tessellation means arranging shapes on a surface so that they fit closely together in a repeated pattern. Can you determine the shapes needed in these patterns?
Tolerances
Most products are made to specific sizes depending on what the product is needed to do and are worked out by the designer. Calculate the maximum and minimum acceptable sizes for these products.
Trigonometry
In this worksheet, you may be asked to calculate the angles or lengths of sides in a triangle. For example, this could be used to mark out a part, to calculate the angle of a taper on a turned part, or to determine the path for a machine tool.
Visualising forms
You may be asked to draw 2D and 3D forms of objects or to use a 3D drawing to create 2D drawings of an object. Complete the projections in this worksheet to show the objects in full.
Volumes
The volume of a complicated shape can be calculated by breaking it down into several simple shapes. See if you can determine the different volumes in our worksheet questions.
